two quetions one about breaks
I would think the brakes may need new pads and/or bleeding. Does this happen when coming to a stop from low or high speed? Maybe a suggestion would be (Of course other than or in addition to checking the pads) getting some S.S. Brake lines..
As far as the clicking? what type of surface(more/less slippery) is the U.G. garage on?
Brakes? Did you check pads? Some owners are having problems with seized calipers. Clicking could be the brake pad wear indicators. See you have SS lines - perhaps brakes not bleed completly? SS line quality varies = maybe they don't seal properly and are leaking or sucking air?
thanks so much so far
the lines i have are ss and are by stoptech
i did have a bad calliper like the others and had to get it replaced....i will check the pads but i think i had them replaced last summer.....thanks very much so far
still having problems
clicking is fixedh however the breaks are real soft
had the brea fluid replaced and bled however they are still quite soft........the break pads are still good
