txbonds 97 4runner limited project
txbonds
Senior Member
UPDATE: NEVER DID SELL ON EBAY BUT MY 1997 4RUNNER DID SELL AND GO TO A NEW HOME UP IN ATLANTA GEORGIA. WITH A NEW FORUM MEMBER. THANKS RON (Rowdyron86), HOPE YOU ENJOY IT AND GIVE IT A GOOD HOME.
In process of restoring a 97 4Runner limited 4x4 that I bought recently with 187,000 miles on it. It is beat up pretty bad on the inside but the mechanical side is in pretty good shape.
I'm replacing carpet, wood trim, seats/covers, center console, etc. when done, it should look almost like new on the inside. And hopefully the wet dog smell goes away. LOL. Prior owner drug his dog around in this thing all the time. Dog ate holes in seats and ate the transfer case shift knob. That's all getting replaced though.
Got it in my air conditioned garage working on interior now.
Pictures:
As purchased interior Condition
Exterior after taking the running boards off
Engine upper end looked pretty clean when replacing seals
Some of the parts going into interior restore/build
Found one more picture of how bad the interior was
In the garage
Also received my new wood kit from Burtman Industries to replace all the faded and delaminated wood dash trim
Got the carpet all removed, the seats removed, and some of the trim removed. Found lots of interesting things under the carpet including nails, screws and about $4 in change. Lots of dirt and pine straw as well. I'll just post some pictures and let them tell the story. Used the real camera finally and not just the phone camera, so hopefully they look a little better.
Old carpet and padding in trash
Misc junk I found in car under everything. Gross.
New items to go back in
Speaker locations
Just for kicks
more pictures:
Foil tape to cover edges of deadener to help prevent possibility of running in summer sun
Drivers side rear quarter panels removed
Passenger side rear quarter panel removed
Some of the filth cleaned up and factory deadener
Some cleaning done, but can't get to everything with just vacuum. Need some brushes and need to get rest of center console out
Hopefully these pictures and build log help the next person that is curious about redoing the inside/outside of an older 3rd generation 4runner.
Putting one of these shallow mount speakers inside rear wall: 10TW3-D4 - Car Audio - Subwoofer Drivers - TW3 - JL Audio
Lots of sound deadener. I know the current belief is that you don't need 100% coverage, but it Works best as small overlapping sheets in my opinion.
I like to put foil tape over the seams on any area that might come into contact with carpet or interior pieces. Just helps to keep the messy butyl from getting on things. In this case, I covered the seams in the opening area where my sub box will be sitting. In other cases I'll cover them under carpet areas.
Next I covered the deadener with a layer of self stick ensolite (closed cell foam) Feels a bit like neoprene.
Lastly, all I have done so far today is inside this rear compartment in the anticipation of getting ready for the sub box. I am going to order/buy some larger foam material to stuff into some of these open areas to limit sound and air flow a bit and to replace the old factory foam that is inside some of these areas.
Ceiling deadening done
Headliner removed. Spent an hour with acetone getting the blue stock blue padding removed.
One layer of deadener with a few pieces overlapped on each panel. All seams taped with foil tape.
Two layers of ensolite closed cell foam overlapped.
It's surprising just how much time these processes take.
Not pictured but additional info:
> alarm installed to get auto door unlock and lock via key fob remote
> JL Audio 700/5 amp refurbished by JL acquired to power stereo
> Sonorn Steel 1.2 kit received from Steve for lift
> Stubbs Welding HD-SKO sliders inbound from Steve at Sonoran Steel
> CBI is currently building a hybrid rear bumper with tire carrier with a few custom order items
> Toyota tundra parts inbound for 199mm brake upgrade (all new yota parts except calipers)
Overall I've got a lot of different parts of this going on a phase 1. Phase 2 will involve front bumper, new front seats and 285/75/16 tires and wheels. Not sure how long my rebuild will take but having fun along the way. :)
Lift showed up today 6/28:
Picked up a few things today:
> 4 channel and 2 channel Rockford Fosgate 5m patch cables - They were old new stock still covered with dust, but are twisted pair cables with a nice black mesh central cover on them and small rca plugs for fitting tight spaces. Got as cheap as mail order, but bought local.
> 75' Stinger 12 gauge speaker wire. Plan to use this for all runs with two pulls to each door and one or two to the sub. I know it's not needed for the watts I'm running, but I like having a little overhead.
> Spare 1 in / 1 out 4 gauge fuse block as the JL amps don't have onboard fuses so I'm going to put one inline just before my amp in addition to the battery fuse.
> My JL Audio 10TW3-D4 10" shallow subwoofer - new in box for the sub box I just had built.
The shop is still working on the trim ring grill, but I went by and picked up my semi finished sub box. At this point, it has been fully resin coated inside and out with a small piece of fiberglass inside over the thinnest panel on the rear for added support. It has been painted black on the rear and has black carpet installed on the front. I'm pleased with how it turned out and I got it for a hell of a price even though it amounted to a lot more man hours than I think they thought it would take when they gave me the quote. Not quite as rounded as a full glass enclosure, but will have some added benefit of being made from birch when it comes to mass, resonance, and overall cabinet stability, and because it is almost fully contained inside the trim the material wasn't as important anyway. The resin is still curing at this point.
The new sub
JL XD700/5 amp out of box finally. Would never know this was a refurbished amp from looking at it. I finally figured out a mounting location that I will be working on tonight and over the weekend. Amp is going on the driver side in the rear quarter panel, sort of like the sub and will be partially recessed. Not so much for stealth as it is to retain cargo space and keep amp at higher level off floor. Didn't want to put under seats in a 4x4 play vehicle in case water ever gets in during a mishap.
Made a little progress on my amp mounting location tonight. space is so tight in these older 4 runners that there are a limited number of places to mount an amp. Unless you are using a micro amp like an arc mini or similar, you are basically limited to under the drivers seat (mine has rear heater under passenger seat) or somewhere in the cargo area. What I typically see is people mount to the back of the seats or to a sub box sitting in the cargo area.
In my case, since I've gone to the effort to get a sub box made to fit inside the rear panel to preserve cargo space, I wanted to do something similar with the amp. The other reason I didn't want to put it under the driver seat is this is a 4x4 and I've had a prior land rover actually get hung up during a river crossing and have water start coming in the doors, which would toast an amp mounted down there.
I chose to go in the rear compartment and on a side. Also chose to go over a wheel well to get it as high as possible. The obvious thought would be directly opposite the sub as there is another pocket inside the panel on the driver side rear, but the problem is there is a pressure vent there that is open to the outside with only a rubber flap to keep water out. I felt like moisture during wet driving might be a problem in that location even though it would have allowed recessing the amp into the wall like the sub.
So, long story short, the amp is where it is and I'm going to make do. Here are the pictures. :)
Using plastic lumber so it's water proof and I don't have to mess with resin to make wood water proof.
Cut a large rectangular piece and then hacked away until it would lay flat on the side wall. Then split it so that an existing factory truck wiring harness could still pass through.
This stuff is 1/2" thick, and it comes in 1/4 and 3/4 options as well. I bought it at West Marine, but you can buy it online and ebay. Hard to see it, but I layered ensolite closed cell foam between the marine board and the sheet metal.
There was already a hole in the side quarter panel where a rear cargo cover would go.
Working now on test fitting initial hole
Once the hole was large enough for the amp to pass through, I put the panel in place and then put the amp in place. Once centered and leveled, I screwed the amp to the plastic marine board. I used all stainless hardware to bolt the board to the sheet metal and to screw the amp to the board. Should be pretty solid.
As you can see, my cutting skills are not quite as precise as the shop that built my sub box and cut the woofer opening on the other quarter panel. But hey, I did it myself and I plan to put a trim ring around the amp when I'm all done anyway to dress it up.
I'm going to pull the amp back down so that I can sound deaden this side, but also so I can wrap the factory wiring in a few layers of electrical tape to give it a little heat insulation from the back of the amp. I'm getting much closer to being ready to start putting deadener down everywhere and to running my wiring. Once I get all of that done, I'll be ready to get the headliner and new carpet back in. My doors are something I can work on after the interior is put back together. :)
Not much progress today even though I spent about 6 hours working on it:
Inside drivers side rear quarter panel. This is basically an air vent with pressure vent to outside.
Starting on the rear floor pan.
Okay, I will officially say I hate doing deadening on these quarter panels as much as I hate doing doors. I think I take the extreme overboard route with most of this stuff. What you can't see in these pictures is the sheer amount of deadener that is down inside those rear wall cavities. Put it this way, I've used an entire 36 sq ft box of deadener at this point just doing the rear quarters and that little bit on the floor.
I'm going to do the rear floor and the 5 doors just as thoroughly but the front floor pan I will not do as heavy as it already has lots of factory deadener and is pretty solid sounding.
Tomorrow I plan to finish the rear floor and the rear seat riser area as well as some of the front floor pan to try to get ready to get the carpet back in. Will have to order more deadener for the doors.
I did order a set of 5 Gloss Jet Black SCS F-5 wheels in 16x8 today. Think that puts me down to tires, front bumper and winch regarding major items still to go this year.
I am curious who the previous owner was. Animal rescue? I hope you got the 4runner for next to nothing.
At least they changed the oil. Can't wait to see the finished project.
With the contents of that fridge on my mind, I am going to fetch myself a Red Stripe now.
Yeah, they changed oil and serviced religiously according to the stack of receipts the truck came with but then let their dog destroy the inside. Go figure.
Few new items showed up ready to be painted and/or installed at some point.
Stubbs welding HD-SKO
Toyota Tundra 199mm Brake Upgrade with:
Toyota OEM rotors
Toyota OEM Front Pads, Pins, Clips, Springs & Shims (199mm)
Toyota OEM Rear Shoes (4runner sized)
NAPA Total Eclipse S13WE Calipers (199mm)
Wheelers Offroad Stainless Front Brake Line Set
Sonoran Steel Stainless Rear Brake Line (not pictured - came with lift)
Very nice looking build. I just took the interior out of mine and found all kinds of neat stuff. lol. *I used a leaf blower to get all the stuff out and then scrubbed away with cleaner.
Yeah, I can't for the life of me figure out how some of the items got to where I found them. :)
Wow! I always love the heavy refurb projects. Amazing to see the wear and neglect
get washed away picture by picture. Great job so far!
May I ask what carpet kit you went with? I've reseached a few (automotiveinteriors.com being highest on list) and would appreciate some more insight on what you chose.
Damn man, quite a project. Shame some d*ck didn't handle the cargo cover better... :)
In all seriousness, I'm really impressed. Very good work do far, looking forward to the finished product.
my thoughts exactly. a lot of time hard work and money going into this rebuild. but it will be worth it your gonna have on heck of a 4runner once you get it back together.
Damn this is a cool thread.
I'm impressed with your audio setup. I love that JL amp and have though about it for future audio projects. Right now I have 2x Alpine amps instead of a single amp but that is fine. I also performed the sound deadening mod back in Spring 07' and it has worked out great.
I am a little curious about the amp mounting spot, do you plan on cleaning it up somehow, those edges look rough and there is a gap. Sorry I notice little things like that.
I can't believe the limited trim you have either. I have a 97 Limited and while I have the plastic wood grain around the AC, everything else is black (cupholder, around shifter etc) ... Perhaps it was a dealer option.
Looks great so far though. Subscribed.
Mike Sargent
