UCA Bolt
MStudt
official vendor
Does anybody know what the bolt size, and length is for the front UCA's? I've looked several times, and can't seem to come up with the size.
How about calling a local Toyota Dealership Parts Department and see if they have one in stock that they can measure for you. Or, maybe you could email one of the Toyota online parts distributors and see if they could help.
Pull the bolt out and measure. Its really not that hard to get out if you have done it before.
I was hoping there was a slight chance someone would know. I have a couple things I need to get ordered today for a project.
I was thinking I might but issue is you always reuse this bold. WHERE IS THE JUNK YARD GUY!
I've got a couple on order, but was hoping to pick something up today for mock-up purposes. Maybe I can get a nut on the side, and go that route for now.
IIRC it's a 9/16 (or whatever metric equivalent is). The distance between the inner sleeves on the UCA is 7", so figure the total bolt is probably 11" long or so.
Thread: M14x1.5
Thread Length: 1.5" from the end
Length (bolt head seating surface to end): 12 3/8"
Maybe you know my question as well....
I bought OEM UCA bushings that came with the sleeve on them. Will I be able to just press the old ones out and new ones in? I see a lot of people buy aftermarket and thus need to reuse the sleeve which means they burn their bushings out. Was wondering if mine will be as easy as press old out and new in like the LCA bushings that I already replaced.
For OEM bushings, press the old out and new in. The burning comes when you are replacing the rubber in the bushings with Polyurethane.
https://www.tacomaworld.com/threads/how-to-replace-upper-lower-control-arm-bushings.280375/
DJNutshell
