UGENT need help with 3rd member
chillaxing
so theres been a whining sound coming from the rear of my 4runner. at first i though it was my rear wheel bearings. Took it to a friend since i dont have the space to work on my car. he worked on it and come to find out it was my 3rd member. I set out on a mission to go find a used one at the salvage yards and finally did. I brought it home today and found out the flange is totally different.
So my question is will this fit or do i need to go return it?
i have an 2006 v6 4runner sport edition 2wd. the 3rd member that i got from the yard was from a 4th gen. I was there and watch them pulling it off.
heres a pic. the one on the right came off my ride.
Today is your lucky day my friend. I swapped my 3rd member for one from ECGS but I ordered one with a "harmonic flange" by accident. It bolted right in no issues there, the bolts I think thread into the flange instead of clamping it with nuts from what I remember. I emailed ECGS about this and they said the harmonic style flange was apparently used on 2wd 4Runners evidently they had a driveline vibration. They said as long as it bolts in it should be fine. I've run mine for a couple thousand miles no issues other than boulders scraping the flange when rock crawling.
Ah, but you are swapping from a 2wd flange to a 4wd flange...
You could get a driveline vibration then.
ah, ok i see now. yes mine is a 2wd and the other came off a 4wd. looks like i might need to drive back 3hrs to return it. I specifically asked if the 4wd was the same as the 2wd and they said yes.
may i ask how much did you pay for the new one? Did you have to pay for the return shipping for the core? I took a quick glance at the ecgs site and i think they charge a core fee. I should have asked question on the forum first before going out and getting the part.
I swear people on forums are more help than the "specialist" the people that are suppose to know these things.
Or we could just trade haha.
Its around $800 all said and done with their oil and shipping. ECGS gets a shipping discount so they can send you a return label in the box which makes it easy.
Definitely get the solid pinion spacer option.
800 isn't bad for a newly rebuild one. salvage yard charged me $500 and another wanted $650 but dont know if its for 4wd or 2wd.
thanks for the help.
3.73 is the stock ratio. But you can re-gear it if your want.
I recently paid 275.00 for a carrier with 70k on it shipped to my door, found it on car-part.com.
what gear ratio am I suppose to pick?
I checked the other threads but still unclear
Divide the number of teeth on the ring gear by the number of teeth on the pinion gear for the gear ratio.
Now would be a good time to regear if you wanted for larger tires, it would cost the same.
I do not understand the problem. Why can't you simply take the flange you want and put it on the new 3rd member? I do it all the time. Just make sure that the nut is staked and you have similar bearing preload and you will be fine.
I was thinking the same, but i already returned the new one, so no go on that. plus for an extra $100+ i can have a new rebuilt one. so i just went with that option.
I have 270k on it, trying to get this thing to over 400k before giving up on her.
