UltraGauge OBDII Scan Tool
bobt4x4r
Is anyone using the UltraGauge OBDII Scan Tool?
Any other recommendations for a scan tool? I would like to read engine oil temperature, pressure, transmission temperature, and volts minimum.
I have a Scangauge II but it will only read transmission temp.
I have an ultragauge that I previously used with a Subaru and transferred over to the 4Runner. I have the older 1.2 version so it doesn't do transmission temp like the newer one does. I don't think I've seen a Oil Pressure option on mine as well. Other than that, it works great as a monitoring tool and scan tool.
Had one for about a month, worked great for the time I had it, only complaint was that the reset button for the fuel gauge was on the back.
Scan Gauge Information
I think I'm going to go to the 4x4 shop and see what they have. I'm going to be pulling a camp trailer and really would like oil and transmission temperature.
Thank you all for your response.
Pretty sure you can't get oil temps, only oil pressure. Your other option for transmission temps is a obdII bluetooth adapter and the Torque app for Android. I believe the scanguage also has transmission temps.
edit: You don't say what Gen or engine you have, but I'm 99% positive the 4.0 V6 does not have the capability for oil temp unless you install an aftermarket gauge.
