Just the sway bar end link...
Not critical, but your call... The car will be a bit more tippy. It's basically bolt on, just go down to the dealer and ask for a front sway bar endlink. They are pricey for what they are if I remember right.
I just got back from Advance Auto, where I picked up their brand of link ends. They're just about an exact match to OEM (comes with washers, rubbers, bolts and all). They were $29 each. I agree with @TheDerk on this one. OEM is best, and have lasted 13 years. If these last half as long, it'll be worth it. They look solid though.
@cj80cruiser: Since I bought 2 to replace, you can have my old one once it's off (that is, if it's not completely rusted and crap, as the passenger side one was). I don't know what it's worth to ya, but it's worth nothing to me. I'll keep ya posted once I make the swap.
Regards.
Thanks! I'm gona cut it and lengthen it. That would be great
on the front I would not lengthen the sway-bar arms. because even lifted we haven't changed the travel length of our front suspension so if you lengthen the sway-bar arm you will limit up travel. In the rear we have actually extended the travel and therefore a sway-bar extension is appropriate. Just my 2 cents
I know the price is a bit of an issue but I really enjoy my WabFab Disconnect end links in front. It takes five minutes to disconnect and 5 minutes to put them back on. I do this while I am airing down. Having them disconnected off-road does make a big difference with the way the front suspension works. Allows it to be more independent as well as droop.
Front Sway Bar Quick Disconnect Installation Instructions | WabFab
They are 140. I just installed a pair, I should have done my research, they aren't as quick as I wished, but they do work just fine!
I bought front and rear kit combined for 225 or so over a year ago. His website is changed and doesnt look like most of the links are working. Basically it is a Hitch pin at the bottom and then a 19mm nut at top to pull them off and put on each time. I have one side that the bushing sticks on and gives me a little trouble removing.
Yukon- that is why they are called disconnects and not quick disconnects. Very stout though and still feel money well spent.
