undercarrage plastic necassary?
HappyHooligan
So I'm missing a bit of the plastic pieces that cover the bottom at the front of the vehicle? and the passenger wheel well piece is starting to come loose.
Do I need all those pieces? Thinking about ripping it out. Or how much would it cost to replace all of them?
The most important one is the piece that covers the fuel lines and fuel filter just under the driver's side door. You don't want your fuel lines rusting out on ya.
The rest in the fender walls helps prevent debris and spray (water/snow) from getting into places that will also rust. The clips are pretty cheap if that's the only reason why they are moving around.
Having those pieces missing isn't going to hurt anything. If it's the one I think you're talking about I think I pulled mine out when I took the bottom (plastic) half of the bumper off.
Talyn
