Undercoating with hydraulic fluid?
DaveK22
Anyone familiar with this? Is it effective? How often does it have to be reapplied? Where would one find a place that does it?
I have never heard of this. Are you not thinking of using oil? That is fairly common. Many hydraulic fluids are water based and might be able to absorb water, and therefore not a very good anti-rust.
In my opinion, forget the oil under the car trick. Instead, use rustoleum or similar treatment. It is what they are built for and they work great for it. Oil has to bee reapplied often, usually several times a winter season if you are doing a good wash down after salting.
Rustoleum is a paint and stays there.
They use chainsaw bar chain oil and spray it on hot. Usually is done once a years for 3 years then touch up as needed. It is messy from what I have been told, but does a great job.
I use used peanut oil. It WILL wash off in high water spray areas (wheel wells) but after some time it dries to more of a waxy substance. It IS messy to apply but is a "natural" oil - not worried about spilling it on me or the environment. It has worked well for me in some of the areas that are prone to rust.
I've used spray-on coatings (paint - undercoating) and the rust seems to grow underneath them and then a lot just flakes off.
I'm going to keep using the used peanut oil for now (have plenty of it that I'd have to get rid of some how anyway).
Spraying the underside with oil is an old farmer's trick that works but since there are more effective underbody protection products I'duse one of them if I were to do anything. I prefer a high pressure wash myself but I'm not in rust country.
Some great ideas. However, so far I like the idea best about Rustoleum paint because seems like you could still do an underneath power spray wash without removing the protectant.
I have had splendid results. My runner's po clearly took care to wash it down, but it did spend it's early years in PA and had some areas to address. Mostly rear tires back where the wheels shoot water and salt up into the crevices. I took a wire brush to the areas and then sprayed with rustoleum... Not a problem since. The flat black matches the original factory metal coat so closely, you would have to be nose close to tell.
Jhunt
