Uneven Brake Pad Wear
Streams
Hi all,
I searched & didn't find anything, so I'm sorry if this is a repost. Please feel free to berate me and direct me to a relevant thread if so.
I went in to replace my pads & rotors, and I noticed that the outer pad was worn much more than the inner. Is there a common issue that could cause this? I figured that because it's filthy, that the outer pad may just be catching on the pin and not disengaging, causing more wear. Please share your thoughts.
Thanks and cheers.
<a href="https://ibb.co/gz5WJnL"><img src="https://i.ibb.co/gz5WJnL/pads.jpg" alt="pads" border="0"></a>
Hi all,
Thanks and cheers.
My best guess is that the outer pistons are sticking a bit and not retracting as they should, it's a common issue on these calipers.
This is one reason I always rebuild or replace calipers on every brake job, every vehicle.
I will not do a "pad slap"
I'm much the same, but I also do a rotor swap, get the old ones turned if they still have enough metal left on them for the next time I need to redo the brakes.
uneven pad wear
On a single piston caliper more wear on the inside is usually a sticking caliper; T4r is the first four piston caliper I've had, but I'd agree with the other posters that it's likely the caliper. I just replaced mine because it has 110k miles and I doubt they were ever changed. I change rotors every brake job and calipers every other. It helps to change the brake fluid every two years as well.
Jhunt
