Unlike any rear window problem i have read?
87gen1jus4mud
I looked for a similar thread but none were the same? I bought an 03 4runner sr5 v6 and everything seamed to work as it should until the rear window wouldn't go down any more, and the rear wiper wouldn't work or the rear defrost. So i looked it up in the owners manual. it said it wont work if the window lock button was on, on the door .So i tried it and sure enough the window worked ! (twice) then never moved again. Sept the wiper works now and the defrost? But no window? So i got out and tried the key on the back door for the window and the dam wiper works with the key in the rear door lock? And then i try the key chain window button and same thing the wiper go's on. Now i am no expert but I'm pretty sure that's not supposed to happen. Is there a way i can reset the windows switch without unhooking the battery and having to reset everything ?
There's an ECU in the back lift gate. Pop off the plastic cover and pull the bottom right connector and count to 10. That should reset the ECU. The only caveat is while I know this resets the door locking motor, I can't remember if the ECU controls the other items on the liftgate. I'm pretty sure it does. Here's a thread on removing the interior panel from the lift gate AKA rear gate AKA rear hatch.
Well, did it work?
I am curious to hear if this works. My problem is a bit different, but think there is an ECU problem. I first noticed my tail gate will not open with unlocking with key remote, but will open if I press unlock button in DS door. When it won't open, the rear trigger is just dead (no click, nothing).
Then I started to dig a little. The key hole won't operate the rear window either. But, the rear window works fine from the dash button. Also, the wiper blade works fine (from the steering column control).
So, nothing works on the tailgate, from the remote or key. But things do work from the controls in the cockpit. (The remote still opens and locks the 4R's front four doors.)
I am assuming I need to replace the back door ECU, but still have hopes it could be a simple connection issue. If it's the ECU, does anyone have a price they paid from the Dealer, for part and install?
KingZ I am having a very similar problem with my 03. I can't open the trunk or move the rear window with my key fob, and nothing on the trunk works if the engine isn't running. Once I get the engine running, I can press unlock in the door and it works fine. Also, the wiper and defrost don't work until I move the rear window.
I talked to a friend at a dealer and he says that the ECU shouldn't need to be replaced because they would either work or not. This is the first that I have heard about "resetting" the ECU though and I will try it out hopefully this weekend.
I'll post back up here if it works or not.
I have the same problem. Key must be on and window opened even slightly, then everything works...until the key is turned off!
Let me know what you find
Update: Problem has developed to include a non functioning defrost, wiper, and window. I have an appt with dealership on Wednesday and will post the findings.
It seems even the little issues are turning into a few hundred dollars for repair. The latest 4 months ago was a $600 charcoal cannister, which was tripping my check engine light. Both in that case and with this tailgate issue, the truck still runs great...but these expensive annoyance repairs are killing me. I still love the truck though:sobbing:
I was working so my wife brought the truck to the dealer. He explained if the rear window is open even a millimeter the accessories like the defrost and wiper will not work. He opened the window from the dash, then closed it, and the defrost and wipers work again. Thought the problem was fixed, so that's all they did and my lady drove away.
Unfortunately, that did not solve the problem. I still cannot open the tailgate with the fob. It can only be done if the vehicle is on, and you hit unlock from the door. :dammit:
Called dealer and will reschedule for later this week or next, and will post results.
I reset the rear ECU and this still did not fix the problem. I talked to a buddy who works for a dealer and he thinks that the issue might reside with the electronics to the rear wiper. If something got screwed up in the wiper's electronics and it doesn't think that the wiper is all the way in the "rest" position, the rear electronics may not work. I'll repost anything new.
Any updates ?
I have the same problem with my 03 V8 SR5 does anyone has an answer
I haven't fixed mine yet. How old is your battery? Also, I recently noticed that my rear window closes very sluggishly near the top. It may be something to do with the window close signal.
with the key, do the open and hold for 10+ then close for 10+, do it like 5x, then go in the car and do it with the switch with key in on, just start the truck so u have some extra power. do it for 5x and see if this solves ur problem, otherwise replace the fuses for the ecu, there should be a couple of them.
I was doing the cycling with the key and then inside switch with the car running. All of a sudden the window stopped and quit moving up. Then I did the drivers door window and then it would work with the key. Tried it again and it would stop and not move at all. If I turn the car on and off, I can start the cycle again?
I pulled the fuses in the drivers side indoor fuse block, same issues.
Ideas?
I had a ground wire break in the hinge on my Land Cruiser, lots of weird things happen. Just a possibility.
Anybody have an update on this? I have an 05 4Runner and the rear door won't open unless the key us on. Rear defrosters only work when I cycle the window with the cockpit controls and the key fob window controls don't work.
I took everything apart and cleaned things up with no resolve. I have not reset the ECU *yet* or tried the key trick in the rear hatch *yet*.
Thanks!
