Update on A/c control panel on 2004 4runner
enfield34
OK I have replaced the relay under the hood, bought another control panel and didnt work. I took it to a local dealership who had a 2005 exactly like mine took out the panel that works in the 2005 and only the clocks work put mine in the 2005 all works fine. any where else i can look at as to why nothing works on panel except clock
I would assume possibly some sort of data communication issue? I'd have to pull up the wiring diagram to see what you'd have to test, but it sounds like possibly either a power supply issue (I don't remember if the clock is separate from the rest of the unit wiring wise or not) and/or a communication with the what ever module supplies the data.
Found out the problem for control panel
Finally had enough and took it to the Toyota dealer after a day and a half they found the problem its the ac amplifier located behind the control panel they had a 2004 4 runner on there lot changed it and it worked So it part number is 88650-35190 it has abs on it now trying to locate a used one close to lafayette la they wanted 650 for part and 350 for labor was crazy since its 3 screws and had the ac control panel offHope this help future people who runs thru this issue
Wow... $650.00 for that part is RIDICULOUS. That same OEM part is available from VILLAGETOYOTAPARTS.com for $337.78 (part# 88650E):
http://www.villagetoyotaparts.com/showAssembly.aspx?ukey_assembly=359375&ukey_make=1021&ukey_model=14403&modelYear=2005&ukey_category=19379&ukey_driveLine=6157&ukey_trimLevel=14102&searchString=ac amplifier
Hope that helps!
I have been having the same issue in my car. Used your part number and just got one on Ebay for 30 dollars. Really hoping this solves it. If it does I owe you big time.
It was the 88650-35190 part that worked for me. I tried the control panel after finding a used one on Ebay for $150 but that didn't fix it. Found a used 88650-35190 on Ebay for $50 and ten minutes later my A/C & fan were working again!
MMJR_T4R
