Mark86
Super Moderator
I haven't modded my truck in a few months and finally found something to do. I changed all of my interior lighting to LED's. I ordered all of my bulbs from v-leds.com, which was a very positive experience. I am very happy with the final product. All of the bulbs were very straight forward to change.
Running boards/Individual door lights/Front map light: 2 HID 6K WHITE HIGH POWER LICENSE PLATE MAP PARKING LED BULBS 194 168 158
You need 10 bulbs or 5 packs from V-LED's (those without running boards need 6 bulbs or 3 packs).
Running Boards- Just crawl under, turn the bulb assembly, assembly comes down, pull out old/push in new bulb, place assembly back in running board and twist. This is probably the trickiest because of the awkward angle.
Doors- Take a philips heads screwdriver and place it between the lens and the door. Be careful because you could scratch the door easily. The entire light assembly comes out and is attached by a wire so don't pull too hard. Disconnecting the wire makes it much easier to work with. Just pull lens off with your hand and swap bulbs. Then snap assembly back in.
Map Lights- I actually pulled the entire assembly down and unplugged it so it would be easier to work on. Just stick a philips head screw driver between the panel and headliner starting with the side closest to the windshield. Once you have enough space for your fingers to fit, pull down and two clips will pop out. Unplug your wire and then you need to remove the lenses with a philips head screwdriver. Work your way around, starting with the side closest to wear you push the light in to turn it on. Be careful because the tabs look fragile.
Middle dome lights and Rear dome lights- You could either buy the 16-LED or 9-LED setup. For my truck with the rear seat audio, the 9-LED bulbs are plenty bright. You need 3 bulbs in total with RSA or 2 without. HID WHITE 9 LED DOME LIGHT 3022 3021 DE3175 6428 6430
Middle Dome (RSA)- pull down cover with hands. Grab the entire lens and yank.
Rear Dome (in cargo area)- use a philips head screwdriver to take off the lens.
Here are the pictures:
