Upgrading front coils?
ryangab
Quick Question! I have a 05 and already have the Daystar Leveling spacer on the front (Budget Boost) and a 1.5 spacer on the back. I want to get Bilsteins 5100 on there instead to lift the front. I want to remove my spacer and possibly put on coils from a 2010 FJ and Bils. Will the 2010 FJ coils work and what notch in the Shock should I set it at for a Level from end.
Thanks!
Yes, any year FJ coils should work. I don't know if they're any different but people I've seen do the switch have made sure the FJ the coils came off were 4x4 models.
I'll let someone else comment on what they think would level you. Read through the suspensions FAQ - there are a couple of links to FJ swap threads you can read through and see if anyone else has done the same setup you're talking about.
http://www.toyota-4runner.org/4th-gen-t4rs/102272-4th-gen-suspension-options-faq.html
youngrk
