Upper Control Arm bushings
joshua.adams.63
I am trying to replace my upper control arm bushings and every set I have got from local stores do not work. Can someone give me the proper part numbers for the right side upper control arm bushings for a 01 4runner. Thanks
Sent from my SM-G920V using Tapatalk
Front UCA's- 48632-35080 (OEM)
Rear UCA's- Whiteline Bushing W63379
Can you post pics please? Consider using energy suspension or OEM. Moods should work. With ES bushings, you will just remove the rubber insert, leaving the sleeve in the UCA.
Crookedcat
