Urgent: I need a temporary DIY solution
Spiggie
I came out to my car after work to find the drivers side floor filled with a puddle of water! Rest of the water soaked in!
The problem is because of a messed up sunroof drainage tube.
If anyone knows How to permanently fix this, that would be awesome!
But I'm worried because of so much water on the floor will that cause any problems?
If you need more details let me know!! Thanks.
It drainage tube clogged or broken? Get a super long flexible wire and gently snake it from the top until you see the bottom. You may also want to pop the body plug to drain some of that water out of the floor pan.
What would happen if I don't pop the body drain plug? Just wondering because this has been happening for quite a while now! Just today was the worst it's gotten. Also I do not think the tube is clogged. I think it isn't connected at the top but I'm not sure..can never see beyond the headliner.
your truck will eventually accumulate a mess of icky, moldy fun. Then I wouldn't suggest driving barefoot at that point.
You will probably have to pull the A pillar trim if thats where they route it.
youngrk
