V6 Engine heating up when AC is on then back to normal when the AC is off.
4runnerV6
2004 V6 4Runner SR5, 227,000 miles.
My temperature gauge will go to red, while sitting in traffic with the AC on,
once I turn off the AC the temp gauge goes back to normal which is mid level.
Where should I start looking for issues, bad thermostat, bad gauge, blockage with the coolant in the radiator, water pump, etc... any information would be helpful. Thank you.
Sounds like a fan clutch or clogged radiator. If your A/C is over pressurized it can put stress on the cooling system too.
If it gets so hot and over pressured and cap does not release the extra pressure,you could split the radiator at some place and trust me this will be a costly repair or even might be a new radiator.
I would contact a real radiator repair shop not your dealer.
erinobr2000
