V8 PCV valve replacement
schan1w
Anyone able to remove the PCV valve on the V8? It's located in front of the oil filter and is screwed on pretty tight (seems tighter than the 20ft-lbs spec). Can't get it off and don't want to use too much torque to get it off. Thanks!
weird. never had a problem getting one off.
The back side is going to have some oil on it. Must just be over tightened.
lindwlson982
