Yeah, Bellingham is a great town. Being so outdoorsy though, 4Runners catch a pretty high dollar in the used market. I looked for quite a while before finding a 4x4 5sp with the 4-cyl. Couldn't be happier with it though...I'm jealous of your turbo 22re though...
So, it has over 200k on the 22re and every once in a while I'll notice a little bit of surging while accelerating at 10-25 mph in second gear. It's pretty negligable but I'm just trying to think of all of the preventative maintenance I could do to keep from having any problems down the road. The idle seems pretty steady at ~850 once warm, not much hunting. That being said, I've noticed that when I take the gas cap off at fill staions there's a vacuum (sucking in) that's pretty noticable. The valve in the cap itself seems to be okay, but I'm not sure if it is the stock cap or not. Also, I took the charcoal canister off this morning and blew air into the inlet and was able to confirm the check valve was working, but I don't have an air compressor so I can't clean it like it shows in the repair manual with 45psi air.
I guess i'm just wondering if there is supposed to be a vacuum on the fuel tank always, or if that might be making the fuel pump struggle a little too hard? The other two cars I've owned ('85 Jeep Wagoneer, '04 Audi TT) have always let out a little pressure when you take the gas cap off. I assume that's from evap. due to temperature change...but I don't know exactly how the Toyotas are designed.
