Valour Exhaust Tip Installation-Easy?
Yup, just slip over the existing exhaust pipe, make sure the drain hole is pointing down (6 o'clock position) and tighten the screw.
I second that!!
morphius909,
It's as easy as installing your TRD tire valve caps.
Wow checked online at a local Edmonton Dealer.
95 bucks for the exhaust tip!
45 from the States.
What a rip!
Also, the cargo net is 35 online. 96 at the Dealer.
Looks likeI'm once again given the US my business :awais:
3A Racing has better looking tips than Valor. The Valor tip for the 4R looks kind of limp beside the 3A Racing 62-2417 ( 2 1/2" inlet ) or 62-2419 ( 3 " inlet ). I had the 62-2417 on my 2004 SE. The 62-2417 is not showing on their website but it is available through distributors. Tip is @ 11" long and 4" in diameter with a slant cut and rolled tip in stainless steel. It also seemed to add a bit of burble to the exhaust at idle, probably due to the mesh baffles inside the tip.
http://www.3aracing.com/pdut_detail.asp?ID=8
To add, there's a clamp. So tighten the screw on the clamp. Not like the 3A Racing which has no clamp. No offense.
will this exhaust tip fit the 4runner
3 ½" Inlet," 4" Outlet x 10" Length
fits 2 ½" to 3 ¼" pipe
I agree
I picked up one of these from AutoZone for just a song. Worked with it for a while, and then removed the "claws" and just used the screws to hold it on. All in all, looks better than the Toyota version and for less than half the price.
I agree
Da*N! I need to see if this is available in Canada then. Or at least some mailorder place in the US.
i found a 3a 62-2417 for 21 and free shipping. Allegro or scoobs can u post a pic of how it looks installed? thanks!
I had a silver 2004 SE and that picture posted by KC is what it looked like. I was able to get mine to stay on using the existing fasteners which attach to the outside of the exhaust pipe by pressure when you tighten the screws. There are 3 screws so it tightens in three different spots around the pipe.
45 from the States.
What a rip!
I just bought a Cargo Net from Sherwood Park toyota for $65 last week.
definately worth every penny though!!
do you guys cut the exhaust pipe at all or just let it run through the tip? i noticed in the picture that it was slid down all the way to the muffler, is the tube cut, or did you just run it through?
