Just purchased a 99 limited w\136k on it. I noticed some oil around the valve gasket. I figured i would try tightening them first before i replace them. The bolts were loose enough to turn by had so i m thinking that might have been the problem. After i tightened them up i drove around and checked under the hood and noticed smoke coming from the rear of the motor on the drivers side. Is this a pretty typical place where these start leaking? Or could it be coming from below the valve cover around the exhaust? I cleaned it up a bit and will check to see if more oil accumulates. Also how tight should i tighten up the bolts around the valve covers
