Valve cover gaskets and then some
dogojoe96
So I noticed a while back that my valve cover gaskets are leaking and it is to a point that it needs to be done. I also plan on replacing the thermostat and heater core soon sense it has been chilly in the mornings here in SW Colorado. Is there any other things I should check or possibly replace while I'm at it?
Well if you don't know the last time the timing belt and water pump were changed I would change them out too. It's a little more hassle but well worth it. Good luck.
charlesz
