shootmymime
hello eveyone in the T4R.ORG world.
done on a 2000 limited with a K@N cold air intake
recently at the mechanic shop we had a nissan xterra come in with a big sludge problem.
i have owned my 4runner for about a 2 years and wanted to take a peek at my heads and upper end.
so here is a step by step on how to check your heads for sludge.
give yourself about an hour to hour and a half depending on how mechanicly inclined you are to do this job
tools you will need.
a 10mm socket with a 6 inch extension and wratchet.
a skinny flat head screw driver about 6 inches long.
a towel to keep oil drips to a minimum.
a drink so you dont over heat.
some problems i did encounter
i broke a pice of the bracket that holds the wires on the valve cover while removing the calve cover so be careful. see step 4
1st step, remove all the hoses and intake from the engine. sorry guys i didnt get to crazy about this part since mine will be a bit diffrent because of my set up. but your plugs and hoses will all be the same.
2nd,remove the Posative Crank case Ventalation Valve (PCV) by pulling straight up, wiggle a bit its pretty easy
3rd, unplug the eletrical clip on the bottom of the throttle body
4th with the 10 mm socket remove the 2 bolts holding down the coil pack wires and injector wires
5th unclip the 3 clips on each of the coil packs
6th remove the 3 screws holding the coil packs on the valve cover and pull the coil packs straight up out of the spark plug wells
7th remove the 8 screws holding the valve cover to the head
a picture of all the 8 screws
this is the part that takes the most work, so take yout time. it goes best taking the front out first followed by the rear.
with patience and alot of back and forth up and down motion with the valve cover and other wires slowly remove the valve cover from the head, there wil be a gasket attached to the valve cover on the bottom side.
and thats about it. i cleaned my valve cover and Mass Air Flow Sensor (MAF) while i had the hood open you can search on that maf cleaning
well there we go, easy job, put everything back the way you took it off.
-sincearly the mechanic
