Valve tap after rebuild
hvguy
I have an odd valve tapping noise coming from the right bank of my V6.
I was careful to be sure and replace the little spacers into the right spot.
I even went back with a feeler gauge and checked their clearances- they were all within spec.
Any idea?
also, I have a lean code
<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/JMZfgyQOO-Y&hl=en"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/JMZfgyQOO-Y&hl=en" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>
I see you got it to start and wondered why it wouldn't before. It sounds responsive, even healthy. Is there enough oil getting up there? Did you do a valve job while it was apart?
no valve job, just new HG then re-assembled.
I spoke with a guy that said the cam bearing caps might be overtightened.
then I got to thinking the cause of the crappy idle is the timing might be off 1 tooth. But that might make up for the lean code, but not the tapping.
I just spoke with the toyota dealership and they said it would be 75$ to diagnose the problem!!!
cheap in my book- im about to button it up and take it to them.
=( although ill feel bad that I didnt get the chance to fix it myself.
Why wouldn't it start before?
DONE!!!
found out the problem,
In my hanes manual it says to install a service bolt in the secondary cam gear. I didnt do that because it showed them removing the actual gear. So I just pulled the cam out and re-installed it later.
well, I found out that there are 2 seperate gears that are spring loaded and your to install a 10mm bolt to keep them aligned....
thats where the tapping is coming from.
and the 5vz-fe is not an interference engine
hvguy said:
DONE!!!
So that fixed the rough idle and the tapping? I think I have figured out the Toyota system. All engines with a timing chain are interference engines. All engines with a timing belt are non interference engines.
lol, that makes sense. chain-usually won't break, belts-break
I also didn't use the 10 MM bolt. Since mine has a rough idle and tapping also what exactly did you do to solve the problem. Remove the valve covers and re-align the gears?
Mine only has a tapping at idle speed, but it does have a rough idle.
Thanks,
Luther
