Vibration after Lifted
Dsimm
03 v8 lifted with toytec ultm3" after the install I have a vibration above25 when under a load. any ideas? Thanks
Just about any lift is going to change your drive shaft angle, which will cause vibes, esp under load.
Some kits supply shims or other means of correcting the angle.
Thanks for the feed back... I have the diff drop kit installed no luck. I did talk to the guys @ Toy tec sounds like I should drop the front end down a bit....Sitting taller the the rear right now. We will see if that works...
