Vibration Issue - Please help Diagnose
Aquanius
Hi there, I am new to the forum having just picked up the 4runner as a surprise for my fiance. It is a 2004 SR5 V6 4x4 with 187,000 miles on it. There was some minor work to be done to it when I picked it up, it needed new rear discs and brakes along with a new CV axle on both sides because of badly torn inner boots. The last major problem was that when accelerating the engine, while powerful, had a much deeper, throaty sound than I am used to on a v6 or any SUV I have been in.
It almost sounded like an exhaust leak that I am used to from other higher HP cars I have worked on. Along with that, I could feel a slight vibration in the accelerator pedal and in the steering wheel. After doing all of the fixes list above, it feels like the vibration has gotten worse in the wheel. This vibration does not move the wheel in any way but feels like it is "buzzing" the steering wheel, just enough to be annoying. It is more pronounced when cornering either right or left, it is the same no matter which way I turn. This does not happen all of the time, it seems to mainly be when going 30+MPH and giving it about half or more throttle.
I have just now checked the U-Joints under the car and they look pretty old and rusted, but they do not move side to side or clunk in any definitive way. I have also heard that the transmission might be the issue, but I think that the transmission issue only happens on shift and for a short time? This happens the whole time that acceleration is occurring.
If anyone can give me any helpful hints, or recommend me to a good shop in the Portland/Beaverton/Tigard area that could help me fix this in the next two weeks before the fiance gets home I would really appreciate it!
TLDR: Vibration at the steering wheel that does not move the wheel but can be felt and is caused by acceleration and feels like the engine might be shaking, and usually when going over 30MPH, and happens the whole time the car is accelerating. Checked U-Joints - They don't seem to be an issue, but should probably be replaced. What else can you think of?
The fact that you "feel" it in the steering wheel could be indicative of a bad wheel bearing. A bad front wheel bearing will get louder the faster you go, regardless of engine RPM. Most of the time, it will sound like a propeller driven airplane when it is loud. Just musing, but worth a look.
Hey everyone. I appreciate the responses, and I am going to look at the wheel bearing. The main reasons I ruled it out at first was because it is not a whirring sound, but definitely an engine growl/deep throaty sound. I also was testing by turning the wheel both ways while this happens and it seems to stay the same no matter which position the wheel are. Does not mean that it is not it.
I will call the shop in Tualatin. Near my work is Clay's Auto and they quoted me $65 to have it on the lift and try to do a quick inspection and see what the problem could be. I was not sure if that was a decent price or not seeing as how they wanted $250 minimum to do the front and rear U Joints even though they were parts that I have already purchased. However, I know very little on what mechanics charge to do those anyways, I was just under the impression, from doing it before on my older pathfinder, that is really is not that much effort once you have it in the air.
I was suspecting the transmission and motor mounts the first time I had the problem because it is acting very similar to the problems I had on my rx7 when the motor mounts were starting to go out. I think I might replace both of those just because.
I had a vibration issue mostly between 30-40mph and 55mph+
i scratched my head at it for 3 months
rebalaced tire ect... nothing worked
it would vibrate turning left or right, in neutral or any forward gear, accelerating or decelerating it didn't matter, it did not whine
I paid toyota $75 to check it
it was the passenger front wheel bearing
i ordered the part from member
Bumper2Bumper Auto
it took me 1.5hrs in my driveway, vibration instantly was gone
Thank you for you suggestions. Sorry for the late reply, work has been hectic. I am going to check the bearings today. Do I need to replace the front drive shafts u joints? That only activates in 4wd correct?
Did you ever figure it out?
Oh with same issue. Think rpm and load sensitive.. Heavy acceleration or steep hills increase the sound and buzzing feeling.
H.Sikina
