vibration issue
7echo
Member
I have a vibration in my truck.
It seems to not be related to a speed range like some of the vibration issues I have read about when searching.
I can feel it in the 4WD drive shifter. Regardless of whether it is in one of the 4WD options or just in 2WD.
I can not feel it in the transmission shifter.
Comments are appreciated.
Check u-joints, brake rotors, tire pressure/balance, engine/transmission mounts and check the alignment of your tires.
There's a few things it could be but that should get you started. There's also a lot of threads about random vibrations as well you should check out.
2001ATL
