Volk TE37 large PCD 18x8
Because Volks only come in 20 or 30 mm offset that I can find... And besides, with a 20mm offset, I'll get 6mm more clearance on the inside and 14 mm more on the outside for a slightly wider track without the need for wheel spacers plus I can go with a slightly wider tire that won't hit/rub the uca or hopefully not..
[MENTION=122369]Ballzz[/MENTION] A couple of things to consider.
3- R40's have an open head because they are meant for extended race studs. I would not use r40's on a truck that you are planning to take offroad because you will introduce mud and muck into the threads of stud making it susceptible to corrosion.
I love R40's and have them on my showcar but with the truck, you really need to think of function as well....
Just my.02 cents.... Good luck to you and make sure you post up some pics when you get your build going! sounds like we have similar taste!
Yea, already thought about that hence the Revos comes with a plastic end cap to keep out the dirt.. but thanks for keeping an eye out..
I'm looking at everything I want for the mods atm, still waiting on the dang trd pro to show up at the stealership...
Several things wrong with this post which makes me wonder where you are getting your information. First, Volk still makes the 0 offset for this application. If not, you can always go with BFD. Second, more negative offset gives you more UCA and tire clearance. A zero offset will have more clearance than +20 wheels in the same width. Again, you are more likely to need spacers with the +20 offset VS the 0 offset.
Good luck with your purchase. Why anyone would pay money for custom wheels in a +20 offset either from a style or tire application standpoint is beyond me. No offense to japsfinest.
Actually, you will get 6mm less clearance on the inside. You will only gain more on the outside. But even with my 18x9 et0, there's plenty of clearance for wider tires even with the 285/65 that I have on. I actually like the -12 offset. Gives a wider stance and footprint. But obviously its your choice. I'm just saying you have more options then you may think.
Level 8 MK6 also an low price option. I wanted Volks but knew i'd be scuffing up my wheels on the trail so it wasn't worth it.
Available in 18" and matte Black. The centercaps are ugly but you weren't going to run caps on your Volks either probably lol..
100730d1382552198-5th-gen-wheel-tire-thread-10.jpg~original
du7u8u5u.jpg~original
IMG_20140207_173521_919_zps3465d1f8.jpg~original
Magnetic4R, whoa thanks, did a search on a different model of the TE37's and found the 18x9 0 offset.. Will be going with those instead.. Where in the bay are you? I'd like to see the wheels on your runner..
Well I don't know the exact pattern but it's 5 lug and fits Subaru's.
Off a WRX or STI? Dpending on the year and model, the bolt pattern will be different.
2002-2005 WRX wheels:
Bolt pattern: 5x100
Centerbore: 56.5mm
Wheel size: 16 x 6.5"
Offset: 53mm
Stock tire: 205/55R16
2006-2008 WRX wheels:
Bolt pattern: 5x100
Centerbore: 56.5mm
Wheel size: 17 x 7.0"
Offset: 53mm
Stock tire: 205/50R17
2009-2010 WRX wheels:
Bolt pattern: 5x100
Centerbore: 56.1mm
Offset: 53mm
Stock tire: 215/50R17
2011-2014 WRX wheels:
Bolt pattern: 5x100
Centerbore: 56.1mm
Wheel size: 17x8.0"
Wheel offset: +53mm
2004 STi wheels:
Bolt pattern: 5x100
Centerbore: 56.1mm
Wheel size: 17 x 7.5"
Offset: +53mm
Tire: 225/45R17
2005-2007 STi wheels:
Bolt pattern: 5x114.3
Centerbore: 56.1mm
Wheel size: 17 x 8.0"
Offset: +53mm
Tire: 225/45R17
2008+ STI wheels:
Centerbore: 56.1mm
Wheel size: 18 x 8.5"
Offset: +55mm
Tire: 245/40R18
2015+ WRX wheels:
Centerbore: 56.1mm
Wheel size: 17 x 8"
Offset: +55mm
Tire: 235/45R17
Bolt pattern: 5x100
Centerbore: 56.5mm
Offset: 53mm
Bolt pattern: 5x100
Centerbore: 56.5mm
Offset: 53mm
Bolt pattern: 5x100
Centerbore: 56.1mm
Offset: 53mm
Bolt pattern: 5x100
Centerbore: 56.1mm
Wheel size: 17x8.0"
Wheel offset: +53mm
2004 STi wheels:
Bolt pattern: 5x100
Centerbore: 56.1mm
Offset: +53mm
Tire: 225/45R17
Centerbore: 56.1mm
Offset: +53mm
Tire: 225/45R17
2008+ STI wheels:
Centerbore: 56.1mm
Offset: +55mm
Tire: 245/40R18
2015+ WRX wheels:
Centerbore: 56.1mm
Wheel size: 17 x 8"
Offset: +55mm
Tire: 235/45R17
Volk Racing TE37 18x7.5 / 5x100 / Offset +48
Milpitas, here's a couple of recent pix
volks
japsfinest...what would you consider is the right price
you have 18s and 20s
specs please on the wheel and tire combo
i have a 2015 trail premium no lift yet I'm looking for some new shoes for the truck
magnetic4R what is the wheel and tire spec on that truck its sick
im assuming no lift?
i like that look
i like that look
I believe his are 18x8 and the 20s are 5 lugs for his car.
As for mine, they are 18x9 0et, 285/65 BF KO. -12et would have been perfect.
Yes, no lift at the moment, 2" in progress.
My 20s look great on stock height, but 18s will look better with a lift.
magnetic4r which are the 18s and which are the 20s which picture is which? I'm confused a bit now
Both pic on the 4runner are 18's, He has 18x8 and I have 18x9. The 20's I was referring to was the pix of the box he posted which i assumed you were referencing. 4runner are 6 lugs and the 20's he has are 5 lugs.
i like that look
[MENTION=118423]555R[/MENTION]
My 18's are on the 4Runner. The 20's are on my GTR.
The 18's 18X8. I run a +30 in the front and +20 in the rear. Both with a 1.25" spacer to have the tires kick out past the body.... I am not a fan of a flush look on a truck so I made sure to to go aggressive with the firmest and tire size. I run 285X65x18 all around
285/65/18s fit on an unlifted 4 runner? any cutting or mods clearance issues might be what? i think that looks pretty badass
Push the liner forward and you should be set. The rest depends on your tires brand. I rubbed more with my 20s only because of the -12 offset. I feel like I can run 295 or even 305 with the BF KO with lil rubbing but drive able.
