vsc abs light solved.
calimobber
Member
Idk if anyone remembers me having the issue when I put it into reverse I would get a abs light with vsc lights also. Also the right reverse light would dim when I hit the brake.
Turns out it was the ground bolt for all the rear right lights. It was not super tight and had a very weak ground. So the when I was in reverse it worked but when I hit the brake the added amps from the other bulbs it failed.
I must have never tightened it after using it for a ground. So a place to check if your having issues when you go into reverse is check the grounding on both light housings.
DionicioLives
