Did you actually have the VSC light AND the engine light on at the same time? Did the dealer say that you had an evap leak when they did the diagnostic test? I thought my problems were gone because the lights went out, but as of just this Sunday, they came on again!!! I was sitting/idling for about 10 minutes looking at a paper and when I looked up the lights were on. I did get gas the night before and didn't really push and tighten my gas cap as securely as I have been more recently, so I am almost thinking I have a bad gas cap that may be leaking some fumes to cause the lights to go on, but I'm not sure.... Can you give me more input what your experience was?ttenrag said:I had the same problem with my 4runner, and the dealer had to replace the oxygen filter which is connected to the manifold.
MJB said:Did you actually have the VSC light AND the engine light on at the same time? Did the dealer say that you had an evap leak when they did the diagnostic test? I thought my problems were gone because the lights went out, but as of just this Sunday, they came on again!!! I was sitting/idling for about 10 minutes looking at a paper and when I looked up the lights were on. I did get gas the night before and didn't really push and tighten my gas cap as securely as I have been more recently, so I am almost thinking I have a bad gas cap that may be leaking some fumes to cause the lights to go on, but I'm not sure.... Can you give me more input what your experience was?
slowginjoe said:a loose gas cap should not cause the VSC light to go on, just the check engine light. when i had the sulfur TSB done, one of the things it involves is reprogramming the ECU. after they did that they couldn't figure out why the VSC and check engine lights were on. they didn't realize that the yaw sensors needed to be recalibrated after reprogramming the ECU. the yaw sensors are part of the VSC system. they would not let me leave with my truck until they fixed that for liability purposes.
so, did you by any chance have work done to your truck recently which might of require ECU reprogramming?
sharp4runr said:I've had the VSC and the VSC OFF lights come on after getting the Sulfur TSB done. They replaced the shorted terminals and that has fixed it.
MJB said:Did you have the Sulfer TSB done because your engine light came on and that's when the VSC lights came on (so I can understand the sequence of your situation)?
