vsc light problem?
saabpowered
this has been bugging the he!! out of me for a couple days now and I am out of ideas.. Recently my pinion bearing went out and I had to pull the third member out... in the proccess of doing removing the axles I broke an ABS sensor and the ABS, BRAKE!, VSC, and the car with squiggly lines lights all came on. I replaced the sensor and all but the VSC and car Squiggly lines light turned off.... Now I noticed today that my auto LSD is not working either.... any thoughts?
Look for my write up here and try this if the zero point calibration doesn't work for you. http://www.toyota-4runner.org/4th-gen-t4rs/191643-f-%*ing-dash-lights-2.html#post1961688
I know its been awhile since i responded. Kinda got into my saltwater tank hobby... But i tried the calibration and all i get is a flashing abs light and nothing goes off. I did try to plug a code scanner into it and i keep getting a right rear abs code but the abs does work i tried it out. I also noticed 2 things the other day. One being that the package the sensor came in has a different part number then what my truck calls for. So i looked it up and its a abs sensor for the Lexus equivalent of the 4 runner. the gx if i am right. Now everything plugged in right and its look exactly like the Toyota abs sensor. The next thing is the other day i was in reverse and i backed up quite fast (about 25mph) and my abs light and BRAKE! light along with all the others came on. Now once i put it in drive and rolled forward the abs and BRAKE! light shut off. I am a little stumped as to what is causing my truck to not want to calibrate... kinda aggravating if you ask me. On a side note i did haven't check for a broken abs wire but i assumed it they where Ok since the abs worked.
