VSC, TC & now ABS dash lights on
Jay Nice
The problem started when the wife filled up with gas, cap wasn't sealed tight enough, I verified this. Threw the engine light & VSC lights on. Tightened the cap & drove it for about a week and then it seemed to have reset itself? All the lights turned off but only momentarily, then the dash lights came back on minus the engine light this time but now the ABS light is also on with VSC?
Looking for a bit of advise here... I'm assuming I should follow the procedure below or should I just go to a local autovalue to have an ODBII reset these?
http://www.toyota-4runner.org/probl...ac-vsc-off-lights-zero-point-calibration.html
Thanks in advance!
I found all my info related to the cap by searching the forum, so thank you!
Jay
i would try these two simple things here first:
1. go get a free diag scan at a local auto parts store to see what the codes are (if any)
2. purchase a new gas cap. you had this issue before, so i bet the gas cap seal isn't holding as it should -- this happened to me. so if you replace the gas cap, pull the negative cable, and that fixes it then you're good to go. however, if it doesn't, return the gas cap, and let us know what's going on.
youngrk
