VSC Trac light
Oldlady4runner
Ok so I have a 2007 sport and the vsc light is on and there is another like with a car that has tracks behind it that are on. I have looked for the vsc Trac button but there isn't one. The only buttons I have on the left side of my dash is a red light that you can push in and sometimes it will light up. The other light is the auto LSD. Am I just dumb and not looking in the right place or what? I would like to get the lights turned off because they are pissing me off.
For whatever reason, Toyota decided to tie certain malfunctions and faults to the vehicle stability system. Most likely you have a problem with the emissions system, either a bad sensor, leaky gas cap, etc. You can take your truck to autozone and they can pull the OBD fault codes. Search for them here and you will likely find out what the problem is before you take it to the dealer and have them pitch you some service package. My truck was having the same problem and it turned out it was a bad gas cap. Pull the codes first though before you go out and buy a gas cap.
Laredotx
