VSC, TRAC & other STAR system experiences
sharp4runr said:
EBD = Electronic Brake Distribution probably played a HUGE factor in that too. Its suppose to modulate braking on the 4 wheels to keep you as straight as possible and avoid fishtailing...
But, it's main function is to distribute braking power front to rear...to reduce brake pad wear & tear.
A Toyota with Electronic Brake-force Distribution reapportions brake-force to each wheel, reducing forward tilt to keep the vehicle more balanced.
Electronic Brake-force Distribution minimizes back-to-front tilt because it has sensors that recognize the extra
load that the cargo puts on the rear axle. The Electronic Brake-force Distribution system responds to an abrupt
stop by increasing brake pressure on the rear wheels, which helps keep you and your cargo safe and sound.
Ahh, thanks for clearing that up Thai. Got that quote from Toyo's site...
Just for your information, electronic brake-force distribution is just a higher tech version of something called a proportioning valve, which was a "mechanical" valve used for the same exact thing.
So this technology is nothing new at all, except now it is electronic and responds to extra cargo weight.
DanielShawSZ
