Pikeman
I ordered the WabFab end links and disconnects for my 98. I just installed the today and was pretty straightforward install. The only issue I had is I ran out of WD40 after spraying the first two, needless to say the two I did not spray gave me a hard time taking them off.
Now for my question. Those of you that have these installed how much room is left between the sway bar and the lower control link in the rear? I am running the SS1.2 in the rear which came with brakets to raise the sway bar 1" I set the new end links about 3" longer then stock but that puts them with about 1" of clearance above the link arm. Do you think that as I go into stuff this might hit or bind? The sway bar now sits parrellel to the ground instead of up at that steep angle.
