Want to run OEM LED low/halogen high beam housings in a 2020 ORP
I want to run the OEM LED low/halogen high beam housings in my wife's 2020 ORP. I read a ton of the threads on this forum and some of it is confusing. I have no desire to get the OEM LED low/high beam setup as we rarely run the high beams and honestly find the halogen lighting on the high beams to be plenty strong.
I just want to make sure I understand things correctly before ordering parts. Based on my research, I need to order and complete the following to do the conversion:
LED w/ Halogen High beam
Left: part# 81070-35600
Right: part# 81140-35610
I can then unpin the low beam connectors from the old housings and install install onto the new housing and that's it to complete the conversion.
If I don't want to unpin the wires and swap connecters, I can buy the "No shutter" harness here: 4Runner 2014 - 2020 OEM bi-LED Headlight Conversion Harness | FBC Harness Solutions
Thanks for the help.
I just looked up everything, from the original post and it looks like you are good to go with your parts!
I don't know if the part numbers are correct but I did this exact install on my '19 TRD ORP. I got a set of used headlights from a '21 T4R off of ebay. I did the unpin deal as there was no harness available at that time. No problems at all and they work & look great.
In case you aren't already I'd suggest swapping out the fog lights with an OEM LED set to match. They are a direct swap as the connector is the same and will be easy to install since you'll already have the bumper off to install the headlights.
Thanks. And yep, we installed the Pro LED fog lights when we did the Pro grill, front and rear scuff plates, etc.
charlesz
