Warm up/ idle RPM'S
Camokid84
I noticed over the month or so that I have had my 1994 4 runner with the 3.0, that when I start it cold, it likes to hover around 1600-1800 RPM'S. Whens its warm it likes 900-1100. I replaced the valve cover gaskets, cam plugs and plenuim gasket last Saturday, and I noticed that when I put everything together, both perameters were raised about 200-300. So I lowered it to about 1100 for warm up, and about 500 for idle. Is this too low? Also I was curious if the higher RPM ranges it was at was contributing to my horrible gas mileage. I about using about half a tank to go 80 miles.
Sounds vacuum related to me. Check all the vacuum lines for leaks and ensure they are going to the correct places. Without lighting it, I run propane torch slowly over all the vacuum lines. If the RPM's drop you know there is a leak there.
