4RNR-LOVN
I can't believe it...took the 4Runner in to the dealer to flush and change the coolant and asked them to check the rotors while it was in as I've felt a slight vibration over the past six months.
The service writer just called me and said it indeed has some runout on the fronts. But get this, he tries to tell me that this isn't a warranty related item...with only 28k miles on the odo which probably started at around 20k miles. What's wierd is that the vibration when braking really wasn't that bad. I've had a vehicle with warped rotors before and the vib's were much worse. In fact, the steering wheel didn't really shudder at all, I could feel it more in the pedal and the seat than anything. So...I remained as calm as I could and said that it was unacceptable that this should be considered an out of warranty item and that rotors are clearly part of the bumper to bumper warranty. Well, he just called back as I was typing this and said Toyota will be replacing the rotors but they want us to pick up the tab on the pads ($55 bucks) since they were down to around 35-40%. I told him that was fine but I want to see the old pads and compare them to a new set out of the box becuase if there is more than 50% left then Toyota is going to cover the pads as well.
This sucks!!!
This sucks!!!
