fireusaf New member Feb 17, 2010 #1 Ok I think My washer fluid jug that is mounted in front of the battery has a crack in it, anyone know where to buy a replacment? 1991 T4R
turboSR5 New member Feb 17, 2010 #2 I would check Ebay, craigslist for parted out vehicles or jimsgotparts.com for a used one. Otherwise you can probably get a new one at the dealer.
90toytruck. New member Feb 18, 2010 #3 found one in great shape looks almost new 12 bucks wrecking yard :reddance:
bosmob New member Feb 18, 2010 #4 hey since you're talking about washer fluids and such... do the Second Gen 4Runners have a different pump for the front washer and rear washer? My rear washer nozzle works fine but my front ones have never worked.
90toytruck. New member Feb 19, 2010 #5 ck the pump first off then ck the in line ck valve and if all thats good ck the lines from the pump to the nozzles !!! if it is the pump they are cheap !!! and easy to replace and yes there are two pumps on the same resivior
