Watson's Build
levi.watson
So this won't be anything too terribly exciting for most of y'all, but for me it is hah. This will be my build thread for my 89 4Runner that I will be slowly adding to, for my own records and so I can ask more questions =).
When I started:
4Runner had been sitting in the field 3 years, put there by a head gasket/other issues.
Stock everything as I know. It was my parents, it was totaled in the first month of their owning it, mom fell asleep and rolled it. Luckily she was fine, the car got put back together, move on 20 more years and it's in the field. I bought a 97 Subaru Outback that had blown HG's (unknowingly), and that put that one in the field as well. I traded my dad for his 4Runner and bought a rebuilt engine from Oregon Engine Rebuilders, which my dad and I put it in over the course of two months. Neither of us had done any mechanic work of this type before, so there was lots of forum searching and YouTubing. Now I have it still fairly stock, with pretty much all new engine components that were needing replaced. Only things that aren't stock are the tires (30") and an electric fan instead of the clutch driven fan.
The treads you see on the easy out definitely deserve to be in here, they probably represented the hardest part of this entire process. I was installing the new oil pressure sending unit, and decided to torque it a little too much. Broke off. Not the end of the world, shouldn't be too hard to get off, and it's like a $10 part. Wrong. It was REALLY hard to get out. I had to leave the next day to go to a conference, so my dad got the joy of pulling it out. Ended up breaking an easyout on it, getting that stuck in there, and then having to take the blurry cone looking deal and grinding that out, and then taking another easyout to pull it out. Glad to miss out on that one.
The last picture is one also representing triumph, as we finally got the engine to hook into the bell housing.... that took a couple nights! Planning a big overhaul on my interior (that looks like crap) either this weekend or next.
*Can someone tell me how to add captions to the pictures? Slightly annoying that I can't figure that one out ha.
Nice build!
When you paste the Image URL in you post it would have a line that starts with
"..." Then ends with [FORWARD SLASH IMG]
Just type text before or after that line.
Nice build!
I once had a chain that was lifting an engine fail. It made a really loud noise when it hit the pavement below, about where your head is in that picture.
Spend $50 on an engine stand from Harbor Freight and don't risk it, please. Makes my skin crawl when I see that shot.
Your Naked Wrenching shot got pirated and made it to the month of July on the Cougar Calendar. Congratulations.
Yeah, I see your point... Probably not the smartest move. I think at that point we had taken it off the engine stand and I was doing something real quick before we put it in...
Real men pull motors barefoot.
Oh. And nice truck. Get it running.
Thanks man! It's running good now, just slowly working on some upgrades.
Has anyone had any luck installing aftermarket seat heaters? I've bought two pairs from amazon and both haven't worked well. Slightly disappointing.
Got some work done tonight, ran into one problem. I'm working on getting to the heater core, but I'm having a hard time getting all the HVAC system out. Center over to the right isn't coming out, but it all feels super loose. Thoughts?
IMG_5881_zpso4vp3kt7.jpg~original
Pulled the seats, pulling the carpet.
IMG_5907_zps63cjdq6h.jpg~original
These are the ones that are giving me a really hard time.
Also, there were wires/connectors that weren't being used in the dash, anyone know what those are to? And, there was this thing, curious what it's to. Does this mean my computer is compatible with a tachometer? It sits on top of the HVAC stuff on the passenger side.
IMG_5904_zpsy2amauhn.jpg~original
Got the heater core out tonight (this morning). Took a while to figure out that I needed to disconnect hoses in the engine bay. Figures.
Why is it the last thing under the dash?
IMG_5927_zps35vxeb8g.jpg~original
Thoughts on the best method of cleaning these is? I'm debating acid or seeing if someone can re-rod it.
Ok! So I got the seats in, carpet in, and now there are some various random things to put back in. All in all, I'm happy with how it turned out. However, I have a question.
Back window: Won't roll down, I got it to once, using the key, but it randomly shut off now. It would do this intermittently before all the work. the back wiper is pushed up where it belongs, any other thoughts?
Hoping to go out to Three Forks in OR this weekend, so hopefully everything doesn't fall apart haha.
IIRC, the fuel gauge sending unit for an SR5 has two separate parts for sending info to the dash. One is for the gauge, the other is the low fuel light.
Check the unit in the tank, there's an inspection panel under the rear seat to get at it without dropping the tank. See if you pulled or disconnected one of the wires before you pull the sending unit out.
Thanks!
I took a look at the wires, they're fine. I don't know if it makes a difference, but before I pulled the dash and everything apart, it worked fine, and first time starting up it was broken. That leads me to believe that it's something from what I did. I didn't mess around the tank at all.
Thoughts on that? I would prefer to not drop the tank hah.
Try swapping just the low fuel bulb back over to a regular one, the led may be seeing a slight bit of current coming through, and because they don't need much to illuminate, it could be lighting up because of it.
I have a few led bulbs in my dash that sees current and lights up really dim whenever I touch the brake lights, its strange but I've gotten used to it.
seltzernator
