If you are NOT a detailing junkie, stay away from the #40 this and the #58 that and the #69 whatever.
Each of them have specific applications and abrasive properties that could ruin paint in the hands of an amateur.
Get Meguires NXT 2.0. It is by FAR the easiest to use, and leaves a very nice glossy finish. Goes on easy, let it dry and cure for about 1 hour, and it wipes off in a fine dust.
I used the NXT 2.0 and love it!
Here are some shots after I did mine with that wax in the winter:
http://www.toyota-4runner.org/5th-gen-t4rs/59756-finally-detailed-pics.html
I will say, I would like a wax that 'sheets' the water off the 4R. Every time it gets wet I get the water spots, unless I dry it. I remember products that claimed they 'sheeted' the water, but I do not remember them.
Is it better than S100 which sold at Harley Davidson dealer? I use S100 for years and love it. I am thinking of trying different wax.
I second this. I've used it 3x on my new 4runner since last December. It makes my dark gray Trail shine like it was new.
It causes water to bead up and roll off just fine. My only complaint is that it doesn't seem to last as long as I would expect.
My problem is taking the wax off. It's extremely difficult and go through a lot of terry cloth's to remove the wax (maybe that's my problem?).
Well, I'm a serious detailer; and if water is 'sheeting' off your vehicle you probably have very little if any protection on the surface. If after washing the vehicle and spray rinse; you can remove the sprayer nozzle from your hose for the final rinse and let the water 'sheet' over the surface. This will help avoid water spots while you are carefully drying the vehicle. Now, if it is rain water that is leaving spots, you should look into Meguiars Quik Detailing Mist. Excellent product for removing light dust/pollen, fingerprints... between washes and water spots left after a rain. It's good on paint and glass as well. Spray it on, gently wipe with a quality microfiber towel; leaves a nice silky smooth finish.
i recently picked up a bottle of the Klasse sealant as well, but have yet to use it. also got some optimum no-rinse wash and spray wax. when i washed the rig a couple weeks ago (yep, it's a wreck again already) i found that mixing an ounce of the ONR with my regular wash yielded fantastic results.I use Klasse Polish and the sealant. The product is extremely durable and only needs to be applied twice a year, but it can be difficult to apply without a buffer or if you use to much.
