WD-40 Detailing Trick!
BamaDrewski
I have a 12 year old T4R limited and I decided to detail her today. I have always been frustrated with trying to clean around the door frames on the frame of the truck, the rim around the edges of each door and the tailgate painted areas. I have used simple green and it always leaves a streak – even when diluted. So, I decided to grab a can of WD-40 after reading about how it can clean things. I took a microfiber rag, sprayed some on and wiped everything down. Now it looks like a NEW TRUCK! Best yet, the water displacement of WD40 will help keep it clean for months to come. For all you clean freaks, this is a great trick!
ATF is a hardcore cleaner most people don't realize. I keep some "lightly" burnt stuff (the last to be flushed out the radiator when servicing) as a cleaning solution for badly stained parts and stains on your shop floor etc.
PB BLASTER IS MUCH BETTER AND SMELLS GOOD TOO. Taste great in the morning with breakfast
We used to spray the engines and frames and under the fenders and such on our bikes when I raced motocross to keep the mud and sawdust from sticking to them worked great and so did pam but wd40 was cheaper lol:trophy:
WD-40 is just fish oil in an aerosol can. It won't hurt your paint. Other similar products might depending on their composition. That said, it certainly wouldn't be my cleaning agent of choice...
We use ATF on our fire engines at work. Makes the dash, pump panel, pretty much anywhere you would use armor-all look great. The wd-40 only gets used on tools ie metal parts.
MMJR_T4R
