We now carry Gowelds @ Outdoorlogic
Outdoorlogic
We are happy to add the GoWeld system to our line of growing products. This is a great unit and very easy to use. A must for any back country travel. These are not on the site just yet..PM me for details
T4R Price Till May 1st
$775.00 plus shipping
CA Tax Applies
Specs:
* Most Versatile Battery-Powered Welder
* Highly Portable - Go Anywhere, Weld Anywhere®
* Unrivaled Features
High-tech styling and performance make GOWELD® the premier portable welder. With an on-board computer and proprietary software, welders enjoy a new level of sophistication and ease in portable welding.
GOWELD® is designed for use in rigorous environments and a wide variety of applications. GOWELD® is the newest product from Broco, Inc., a world leader in the welding, cutting and metal alloys fields.
GOWELD® features include:
* On-board computer giving the welder more control resulting in more precise welds in all environments.
* Optical encoder for true speed control from zero to 1,100 inches per minute yielding the least speed variance for more consistent welds. Speed adjustment / correction occurs 675 times per second.
* Heavy-duty, high-torque industrial motor.
* Automatic motor overheat protection and battery over-discharge protection.
* Maximum power rating of 42 volts DC and 200+ amps current achieving excellent joint penetration on plate as thick as one inch.
* All metal chassis for strength and support of the motor, drive assembly, trigger micro-switch, gas valve, circuit board and wire spool.
* LEDs to indicate power, polarity, battery charge condition and motor temperature.
* One year warranty on parts and labor, excluding consumables.
* Handle-mounted micro switch and integral gas valve operate directly off the trigger. Ability to pre-flow and post-flow shielding gas.
* Optional Power Conditioning Unit (PCU) for using GOWELD® as spool gun with conventional welding power sources such as inverter or generator (constant voltage).
Product Name
GOWELD® Professional Portable Battery Welder
Product Number
600155 (Kit)
Rated Output
200 Amps, 42 VDC
Rated Input
200 Amps, 42 VDC (two or three 12 volt batteries)
Duty Cycle
50%
Processes
MIG solid wire welding on mild or stainless steels, with argon/CO2 blend shielding gas. Use electrode positive (+) polarity. FCAW flux-cored wire welding; shielding gas is not required. Use electrode negative (-) polarity. MIG solid aluminum wire welding on aluminum, with 100% argon shielding gas. Use electrode positive (+) polarity.
Wire Spool Size
4" diameter spools
Wire Speed Range
0 to 1100 inches per minute
Wire Diameter Range
.023" to .045", cored or solid wire
UPC #
8-53946-00001-2
Shipping Weight
31 lbs.
Box Dimensions
21.5"L x 15.75"W x 15.75"H
BillM777
