Koz said:There is a shut off dial that maybe partially closed.
Koz
samething happened to me.airbur said:Since new, the force of rear air (heat, a/c) is pretty weak...I can barely feel it at high fan speeds. Is this typical for the 4Runner?
fo'runner said::iagree: Yep........exactly what he just said! You'd be surprised at just how quickly some of the parts are slammed together in these vehicles--especially if it is just before break time at the plant.:corn:
Spider5 said:There is a black rectangular duct that runs past the shifter under the plastic panel. The panel pulls up without removing any screws, check to see if the seals on the duct are straight. Mine had folded over and mis-aligned the duct. The leakage it created surprisingly was significant.
airbur said:No luck....I checked the duct and it was seated correctly. I guess I'm stuck with weak air for passengers.
