Weather stripping on driver door
yodie92
I saw a thread from last year where someone suggested 3M adhesive for the rubber stripping on the door. My 2000 4R has a similar problem, but the stripping has pulled away right at the top rear corner of the driver's door (at the bend of the seal). This causes a lot of wind noise as well as some water to come through. They wanted $180 to replace the seal at the local shop, saying that it has "learned" to keep that shape and glue would only be a temp solution. Is there a less expensive alternative? i.e. Is there anyone who has had great luck with the 3M weatherstipping adhesive? Thanks.
x2 on this issue,
step dads 02 Runner has the same issue on all 4 doors! and the dealer wont cover it...
