Weight Ratio
sauer
Does anybody know what the weight ratio is for a gen3 4Runner? I’m trying to get an idea of what the tongue weight will be if I put it on a trailer.
weight
Is it a stock truck? I have scales and can tell you what MINE weighs, but I would think knowing the weight would not be very helpful. What is your method to figure tongue weight?
this is what I use.
https://www.sherline.com/product/sherline-trailer-tongue-weight-scale/
then you know for sure.
And you should work for about 10-15% so around 500#. But knowing your whole setup would help.
What size trailer, towing rig ect.
Good luck.
Tongue weight will completely depend on how you load the trailer. Anywhere from negative tongue weight to the full 4,000 lbs.
It’s got a SC and a 2” lift is all. I know if I had easy access to scales I could just weigh the front end alone and do the math. I’m putting it on a U-Haul car trailer so there’s only one way to load it. I was just hoping somebody had read an old Motortrend article or something that referenced the ratio so I could have a ballpark idea.
http://www.toyota-4runner.org/4th-gen-t4rs/43214-4th-gen-weight-distribution.html
As close as your gonna get, found it here.
and again, this info has little bearing on what your tongue weight will be, an inch on the trailer can be 100's of LBS, and you will have no way of knowing.
how do you plan on guessing what it is? Move the truck until the trailer tips?
Also what is your tow rig, what is it rated at towing and dead tongue weight?
it really is not as easy as saying my nose weighs X number of lbs, so that's what my weight will be.
Tongue weight has nothing to do with the load weight. You can adjust your tongue weight by how you load the trailer. You do not want it equal...more tongue weight is better than low or no weight. More people have issues by backing up the trailer load instead of putting it forward.
Moment arm formula ... or simply weigh your tow vehicle with trailer and weigh vehicle without tow trailer to find tongue weight. They also make tongue weight scales.
Or....an easier way is mash the ass and your good to go! Start driving and if she wags a little put more on the tongue. At least thats what we hill billy farmers do!
seltzernator
