Awz
Weird running problem happening more often (updated)
I've posted before about my weird running problem.
Only when outside temp is COLD (engine temp doesn't matter)
Only after I top off the fuel tank, after about 20 miles runs fine the rest of the tank.
Check engine light comes on and runs like crap, sometimes stalling out when idling. Recently (last couple of weeks) It no longer has to be cold or topped off. Now it seems that if I can keep the throttle open wide it will run fine. The big problem is that wide open throttle is rarely an option while rock crawling or a good idea. Over the weekend it got to running so bad I completely lost forward power, and smelled really rich. The plug wires were so hot you couldn't touch them, and the ignition coil was hot to the touch (not just warm).
I've replaced the O2 sensor, did a head gasket, cat back, full tune-up, and correctly timed. I'm thinking either a fuel regulator or possibly the coil itself, is starting to have issues. Any ideas? Been fighting this for a long time.
