Weird Sound - Brakes
stever1000
I just replaced the master cylinder and some brake hoses with stuff from Camelback Toyota.
I am now trying to bleed the brakes (already bench bled the master cylinder on the car) and I noticed a weird air sound, like air moving when I press the pedal.
Please check the video out, you can hear the sound mid way through:
https://youtu.be/CpqIyI5Byss
Vacuum leak. The pedal should firm to the point that it cannot move when the engine is off. Or your brake booster is shot.
Prior to changing the master cylinder I was able to build pressure pumping the pedal so I thought the booster was ok
I didn't have the master cylinder completely level when I bled it so I took it off the vehicle and will try again
I should have mentioned when I made the video fluid wasn't moving from the resivoir so I thought air was trapped at the far end....
