Weird sound coming from shocks?
Atreyus
I'm getting a weird sound everytime I'm coasting or coming to a stop it's almost like a clinking sound, could it be my shocks are too short? I'm using KYB Gas-a-just on a 2.5" Day Star spacer lift. Any other thoughts? I'm taking it into my dad's shop this week to found out what's wrong it's pretty annoying. I did manage to fix another noise which was coming from 2 u joints that needed to be replaced.
Just checked the bolts on the shocks and struts everything is tight still no clue where the noise is coming from, I know it's from underneath the truck...
im getting a similar noise , its mainly noticeable on small bumps or when rolling at a slow speed .
I think it may be my axle since its spiting grease, but im not sure since I though axles were only noisy when turning....
Did you install your lift recently?
It's actually both, I have no idea why it's making noises, I was annoyed by the u joint noise got it fixed finally, now this lol.
I've got a weird clicking noise when I go over bumps that's coming from the rear. Almost like a shock bolt has come loose and every time it moves up and down it contacts something. Pretty annoying.
same problem here..
what kind of noise was it making when u replaced ur u-joints? how did u know it was bad?
yeah I'm still having the that noise problem, is your rear shocks one or two bolts? because my KYB's came with 2 bolts.
same problem here..
It kinda sounded like a thuck-a-thuck-a-thuck-a-thuck-a sound if that is remotely descriptive. But took it in and found out my u-joints were bad.
Am I getting those noises from the shocks because I'm using KYB Gas-a-Just? Are they shorter than stock shocks? What shocks would I need to use in the rear? Or am I using the wrong shocks all around...? KYB Gas-a-just all around...
