what amp to buy
rajeev
So im about to buy some jbl p660c in the front and p662's in the back. im trying to figure out whats 4ch amp to pair them with..i've been looking for any amp that will make them sound good as well as deal with their 2ohm speakers..thanks
What's your budget? There are alot of 4 channel amps out there that would work...but it depends on how much you're willing to spend.
Hmm, under 300 huh.
Well, with that, I'll throw this one out first. Even though it's more than $300, it's one of those amps that if you were going to spend just a bit above your budget...it would be a great choice.
Amazon's Price--Amazon.com: JL Audio XD400/4 - Amplifier - 4-channel: Car Electronics
JL's Website--JL Audio XD400/4 Amplifiers - Car Audio Amps & Amplifiers
It's "rated" at 90-100x4 @ 2ohms (depending on input voltage). JL amps are more often than not under-rated...which means you'll get more than that. The 100 watts would come in just above the RMS of the JBL's but still well below the MAX...so they should do great with that power. It has a high sensitivity (SN ratio)..which is good,has all the x-over settings you will need, and is small.
This Sounstream would be a nice choice too..
Amazon.com: Soundstream RUB4.600 100 x 4 4-Channel Amplifier (Midnight Blue): Car Electronics
Has alot of the same "likes" as the JL. Class AB amp that will give cleaner sound vs. a class D.
This Soundstream would be even better (again...a bit over your $300)
Amazon.com: Soundstream REF4.760 4 x 125 4-Channel Amplifier (Midnight Blue): Car Electronics
The Reference series are great amps.
thanks. that helps a lot. the main thing is that i want to make sure i can put enough power to the speakers, but not blow them out as well
Well, the speakers you're looking to install can handle quite a bit of power. You'd be hard pressed to find an amp around your $300 price range that can put out enough wattage (250x4 actual watts) to overpower those.
The more important thing to worry about is giving them enough power with that budget. There are alot of 4 channel amps out there that you can get for under $300...but you have to make sure your getting the power that the manufacturer says you will. Main reason to go with a quality amp...even if it means spending just a bit over your budget.
Some of the more important specs I look at when researching amps is:
-THD (total harmonic distortion). The smaller the percentage, the cleaner and more accurate the sound at the rated power (usually measured at 4ohms...so it will be more at 2ohms).
-S/N (signal to noise ratio). This is how efficient the power is...meaning how much "music" you hear in relation to background noise. Higher the decibel number...the better.
-Damping Factor. This is a measure of how well the amp can control the speaker itself. The higher the damping number...the more clean the sound will be because it means the speakers are more controlled and more accurate.
And one of the things to remember. If you're looking for an amp to run mids/tweets, then you'd be better off with a class AB rather than a class D. There are alot of class D amps on the market (digital) and they are nice due to their usually small size. Class D is great for subs, but AB amps are better for overall sound quality which means they'll make your front stage sound cleaner. The JL amp I posted earlier is a class D...so I do sometimes make exceptions :) If you're thinking of adding a sub later...even a 5 channel class AB/D amp could work too.
i have a sub right now..my plan is to power the speakers with the 4channel and have a monoblock for the sub. i just wasnt sure what amp to buy in terms of watts..i can go over my budget a little, but the main thing is finding a quality amp
Amps / Speakers
I have installed:
SPEAKERS:
My head unit is a Pioneer AVH4300 DVD - Amazon.com: Pioneer AVH-P4300DVD 7" In-Dash Double-DIN DVD AV Receiver with iPod/iPhone Control, Pandora: Electronics - and the sound is LOUD and CLEAN!
Hoop you find a good amp, but those two I 've mentioned are very good and I am very satisfied with them
