What are the 5th gen weak spots?
TejasRunner01
Hey everyone.. I’m creeping over the fence from the 4th gen forum wanting to learn a few things from you 5th gen people.
Having owned a 3rd gen and now a 4th gen, every 4Runner as wonderful as they are can have some weak spots. For 4th gens, weak spots/expensive spots are: 4WD actuators freezing, frame rust, cracking exhaust headers, very expensive to replace AC, secondary air injection pump failure, early model V6 models have head gasket issues etc. Oh and if you have a V8 you better pray your starter doesn’t go out (what was Toyota thinking?).
I’d like to get your take on what the problem areas for 5th gens are.
Also if you have previously owned other generations of 4Runners, how does a 5th compare?
Lastly, do you have an opinion on better or worse years for 5th gens?
Feel free to answer any or all of these questions. Thank you!
Solution
I have the first 5th gen, a 2010 SR5. Original owner 105,000 miles. I off road a lot. Never had a single issue until around 100,000. Cats started going bad, and one of my front cv axles started to get a little slop at the diff. That's it after a rough 100,000. I drive it hard too. Apparently the 2010 is one of the most reliable.
How are the interior bits holding up such as leather? We have a 2010 Lexus RX350 which has been a huge disappointment, specifically the leather.
Anyone else that wants to chime in, feel free!
My '15 Limited only has 58k and the leather still looks like new. Have only had it for a year or so, so not sure what kind of conditioning the previous owner did but it's holding up without signs of wear and tear.
As far as weak spots, my only complaint would be the power / fuel economy. Numbers wise it's better HP, torque, and mpg than my '07 V8, but the exhaust sound and butt-dyno leave me wanting more. I have no doubts that if maintained it will last forever, just wouldn't mind a little more power and a little better mileage.
I don’t think I’d let go of my 08 V8, but when you purchased your 5th gen, did you feel like for what you were getting for your 5th gen, if you had to let go of your V8 4th gen, you would do it?
That loose CV at the diff sounds like the needle bearing has gone out. This has been the most common failure I've seen in 5th gens in all of the owners groups. East Coast Gear Supply makes a bushing to replace it. It's about $60 for the bushing and $75 for the tools to remove/install. Probably takes 1-2 hours depending on how comfortable you are with a wrench. Don't forget to refill the diff with fluid when you're done.
TOYOTA CLAMSHELL BUSHINGS - 2003 & Newer 4runner and GX470
I second that. Needle bearing is garbage. The CV is sloppy off the lot new. As soon as i put a lift on it i swapped out with the ECGS bearing. No more slop
I have the Softex faux leather in both my 4Runner and RAV4. Zero problems with it. Very durable.
No rattles or other unwanted noises which is rather rare as cars tend to age. I did some serious off roading in Colorado two weeks ago and everything worked great.
One of my only "complaints" is when you are off roading, coming to a crest of a hill, it is hard to see over the hood and see where the trail goes. Left? Right? Or straight?
Softex is fantastic. I'll take it over leather without a doubt. Much more durable and it looks great after 8 years of hard use on mine. It literally looks new. Any leather will be well worn by now.
The drivetrain is significantly better than prior gens. The 8.2 is bulletproof and the front diff and CV set are impressively durable.
KDSS is great. For me it was a must have. Drive one with and without back to back.
The week spots IMO are:
Needle bearing in front diff. Common problem. Toyota needs to redesign the diff with a proper bearing.
Some hardware has poor corrosion protection. Lower control arm cam bolts probably come seized from the factory. They're notoriously bad. Skid plate hardware is also very prone to early rust issues.
OEM windshield glass is fragile and cracks really easy. Mine failed when I turned on the wiper heater.
The front suspension is highly prone to harmonic cyclical frequency feedback. Toyota calls this steering flutter. The steering system needs more dynamic damping/stability. Was never an issue for me, but it's a known issue and has been for a lot of years. Toyota needs to fix it.
The body mount at the firewall is too far forward and has to be modified for larger tires.
KDSS is asymmetric. Would be better if it were symmetric like the lc300.
Really needs an engine/transmission update. It's 10 years overdue.
Toyota knows their windshields are too thin. Otherwise why would they have to point out that the last generation Land Cruiser’s windshield was “2mm thicker”?
Power locks, but thats not specific to 5th gen. Its an easy and cheap fix, but the dealer wants big bucks for the repair. Ive done all four of my doors.
I had forgotten about this one. I have replaced the motor in the door lock actuator in the front doors 3 times now. It's easy and cheap, but annoying.
I'll add another annoyance - the TPMS sensor system can only read 4 or 5 at a time so if you use two wheel sets you have to have techstream or something similar just to re-connect every time. And even slightly more annoying is that there is a break in the TMPS sensor frequency range around MY 2017 so later year TPMS don't work with earlier versions. Kind of a head scratcher for me. Why not make things like this super easy? It should be free and take very little effort from Toyota to program the software to do this.
While we're at this annoyance - why not make the battery replaceable? It's just a basic coin battery, but it's encased in epoxy so it's nearly impossible to replace and the sensors are $100 each or something in that range. I never had a dead battery in one, but it'll eventually happen. And it shouldn't cost $100 to swap a $1 battery.
Windshields crack if you hit a bug at freeway speeds
Paint is about as good a budget interior latex
Taping a couple of free LED flashlights from Harbor Freight to the hood is better than using the craptastic halogen headlights that come on the truck
The frame rusts like a 1972 Camaro fenders did unless you spray lanolin all over it and inside of it.
If you dont drive like an 84 year old grandmother you get to visit every gas station on your trip.
It sounds like your are very pleased with your purchase lol
The lift gate is manual and not motorized. Had to be careful on curves and freeway exits because of body roll. No leds, dynamic cruise control and blind spot monitoring on earlier models, thats why Im getting the 2022 limited edition.
Just arrived at my dealer but I noticed there were no step boards. And for 5'6"and shorter folks, its a struggle in getting in and out of the vehicle.
The dealer said its back ordered and should be coming soon(nobody actually knows when).
The 4Runner has very short windows due to a low roof in relation to the seating. This helps in the bright sun as it’s kind of like always having a “hat” on, the roof is your visor.
The drawback to all this is if you’re a long waisted person and over 6’ tall your head will touch the headliner. I have heard on this forum that the models with a sunroof add extra thickness to the roof, and that thickness all comes out of the cabin space. So 2” less headroom on those models.
DJNutshell
